69Coronetrt
Could the build date be wrong? Could the trim tag have been altered or reproduced?
The VIN to SPD for 68 LA is probably about right.
Reproduced fender tags are common.
I'm just not buying the reproduced fender tag idea. Why would the person put a repro tag on a non numbers matching drivetrain 383 car?....without a build sheet how can you get a tag made?
I bought the car because it is the color combination I was looking for and it is a 4 speed car.
Actually, plant location in many cases will determine authenticity. And the rest of your statement, while true, is irrelevant here since the question is the initial introduction of the model run.I really don't think location of where it was built has anything to do with authenticity. Patrick66 is correct on when production may have began. Its close to the same schedule that is used today. Most plants will go down in July for change over. Typically a 2 week change over period, sometimes less, sometimes more. Back then it could of taken much longer if there was a complete sheet metal change. This may have been the case here. One plant may have been still building out while the other was ramping up. Today most plants try to have more than one body shop to minimize down time. They build out in one area of the plant, flip the switch for the conveyor and start producing the new body style right away.
I'm not sure when they actually started selling them but my 69 is built in Oct of 68.
x2 and would be reason enough to alter a tag and VIN from WL to WM imho...WM cars are worth more than WL cars.
Possible typo in the date code, A "B" instead of an 8 would make more sense,indicating an early Bee in the proper time frame.
I don`t see a 115!!The earliest listed SPD on the Super Bee Registry is 115: http://superbeeregistry.com/
I must be looking at the wrong thing then!? I see two 115...
Upper left is the index for 68 Super Bee, look at "Build Date" then...I must be looking at the wrong thing then!
Ahh,Ok Got it Thanks!!Upper left is the index for 68 Super Bee, look at "Build Date" then...
How??? We're not talking about many cases. We're talking about this case.Actually, plant location in many cases will determine authenticity. And the rest of your statement, while true, is irrelevant here since the question is the initial introduction of the model run.
WileERobby
How???.
Because a car doesn't get sold until February doesn't mean it wasn't built much earlier.
I look at a Car. It's VIN is RM23U0G. Is it a legit car?
I look at a 69 Super Bee. WM21J9E. Legit car?
I look at a 70 Chrysler Hurst 300 car. CM23U0F. Legit car?
69 6bbl Road Runner. RM21M9G. Legit car?
Plant CAN determine authenticity.
He says it was built in August of 67 which lines up with the start of production in July...:argue:Not sure how you'd sell a car in February that was built in March.....
When you have something that is out of the norm, it's best to have rock solid documentation or a plausible story.
