Slightly more like 3/4.Half groove, correct?
Doug
No need to file slots on the Clevite MS2233HG . They are notched already.
Doug
In this instance the thrust was the concern. As you can see the trust surfaces are heavily relieved. Personally I like the 3/4 groove as well. Cleite has done testing for those style grooves. According to Clevite they performed better than other styles. I'm sure Clevite/Mahle knows more about bearings than all of us.Looking at that picture are you talking about the grooves at the top Center of the cap half bearings? What about the thrust bearing? The relief grooves on the sides? Just making sure…
I always used Clevite 77. Would you know if these bearings would be an upgrade or are they specific for high power situationsI
So do you still opt to drill this bearing Kim? Or another manufacturer you are using?Clevite was considered an upgrade cause their a tri metal bearing which is harder/tougher than a run of the mill stock soft bearing. Kim
Doug
Run a HV pump w 5w/25 0il. To be honest the groove won't affect pressure. The grooves are larger than the bearing clearance itself. That's what controls the leak.Do you think this bearing would suggest using a high volume pump? Do you think this affects oil pressure? Viscosity choice?
