JG1966
Thanks Don, but I have 7/16 bolts not 5/16, so I think I needed a higher torque. 25 ft lbs seemed way too loose. I pulled them back out and will reinstall when I am sure of proper torque. I've seen everything from 40 ft lbs to 85. Does anyone know what 7/16 Grade 8 converter bolts get torqued to?Oh boy, I think that's kind of high, they are not big bolts.
I think you may have looked at the wrong row in the chart.
I found this which I believe to be correct (pretty sure it matches my Mopar book on Magnum small blocks at home).
Torque Converter to Flexplate Bolt 270 in/lbs 5/16-24
That is 22.5 in ft/lbs.
