Malicious
Hi all,
This is my first auto, couldn't afford to go manual yet, so I've just started up my coronet, sorted the break in and basic tune and turned to sorting out the tranny.
Manual says that it should take about 8.5 liters, I had 4lt in it showing full so we started moving through the gears with some revs to get fluid pumping through the system (fresh build). Topped it up a few times and got the auto engaging drive and finally reverse.
I had a mate over to help, he sorted the fluid situation while I sorted out the throttle linkages - had a few issues.
After we finally got fluid going through and reverse started going, I noticed auto fluid coming from the front of the trans at the bottom of the bell housing.
I checked the dip stick and it's showing over full.
I'm assuming the fluid is coming from the front seal and I'm hoping it's from my dick of a mate over filling it. However, being my first auto, I wanted to ask you all.
One last fact, my mate was revving in gear and holding the breaks occasionally while revving to motivate the fluid into the converter. Not sure if this might have been a bad idea?
Thanks guys
Thanks guys
