I've built close to 30 727's in last year or two. No leak complaints except one. It was due to a worn converter hub. Most all had stock pans and cork pan gaskets. If the converter and drive shaft yoke are good, they won't leak. If it restarts imediately after stalling it shouldn't be a coil issue. Could be a poor connection in the primary circuit. I'd look at the ignition switch, firewall bulkhead connector, ballast resitor, underhood wiring, wiring internal to the distributor.
Doug
Doug
