68gtx
tossing aroundthe idea of a gear vendors overdrive for behind my 727 in a little project im building, anyone have any experience with them? are they holding up? worth buying used?? or stick with new?
There's a very extensive post on C-C about the "6" speed part of the comments here. This being said GV may have worked that problem out by now. Out side of that a buddy of mine ran one and loved it. Then I found out another guy I know ran one also, he liked his too. I've thougt about it in my E-BODY. I'm currenty running 3.23's so I can hi-way cruise. With a GV I could run 3.91 and still have a 3.08 for the hi-way. That would ROCK!!!!! My HEMI would be allot more fun, thats for sure. Dont like the idea of hammering my tunnel tho..........
If you have a cam that requires that kind of stall it will feel lazey at lower rpms. If you want to cruise at a lower rpm the motor has to be built with that in mind "theirs always a trade off". As for me I've heard nothing but good things about them and have thought about getting one but really think a 6 speed manual would be right up my alley.I wish I knew that suggestion about high stall converters!
I have a GV in the Charger. I also have a 9 3/4" 3000 stall converter. The car feels lazy at freeway speeds. While cruising along at 65, it runs under the stall rating and feels sluggish.
I just don't see the "split shifting" thing as something people would actually do, not a problem, just not all that great a value.
i have one in my roadrunner and its awesome.....customer service excellent.....has been around for years.....holds up to horsepower and if you just happen to have 2000 hp they can beef one up for you too......money well spenttossing aroundthe idea of a gear vendors overdrive for behind my 727 in a little project im building, anyone have any experience with them? are they holding up? worth buying used?? or stick with new?
Gas mileage increase just from a $2800.00 OD unit will likely take forever to pay itself back but that's not the whole story for me. The lower cruise RPM will make for a much more enjoyable driving experience if you road trip your car. Pay back of the OD expense depends on your engine build, but unless you have access to fully computer controlled spark timing, EFI, etc.. to take full advantage of the lower cruising RPM your gains might not justify the expense of these OD trannys or bolt-ons.
Yes............I am old.
