It takes less than THREE seconds!
1. finger OFF the trigger and point at the GROUND.
2a. (semiauto) drop the mag, pull the slide back and look IN the chamber.
2b. (revolver) pull the rod and drop the cylinder, and look to see if there are bullets in the cylinder.
Clear the mag FIRST.
If you have a full mag and rack the slide to check the chamber...when you release the slide, you just loaded the chamber.
Mag FIRST is drilled into my head due to the disassembly requirements of my Springfield's (XDs and Hellcat) - lock back slide, rotate slide release lever, release slide, pull trigger, remove slide.
Mag.
Out.
FIRST.
Always.
"If you ever watch trap shooters, they always shoot both shells off even if they hit on the first one."
Not exactly. I've been shooting trap competitively for 8 years, and with the exception of doubles, regulation trap requires only one shell to be loaded per target.
Any organized shoot that I'm aware of or participated in follows ATA rules which only allows one live round in singles, two for doubles. Maybe you were watching a session of doubles at the time. It wouldn't make much sense to have 50 rounds of ammo for only 25 targets, nor economically feasible.I'm not an expert and I have only been to a few shoots, but every time I saw them load two shells, they would shoot both shells. Regardless of hit or miss on first shot. I'm sure there are different requirements for different shoots.
Certainly there are several people here in trouble, or should be! However, as a long time firearms instructor, you NEVER trust anyone that a weapon is safe! When you receive a weapon from anyone, it should be magazine removed and locked open handed butt first for a semi auto and for a revolver - cylinder open, empty and passed butt first showing empty cylinder to the person so they can see its empty. If it’s not that way, you don’t take it! Period! If you pick a firearm up, it is your job to clear it. Period. It’s on Baldwin! He received it, pointed it, and squeezed the trigger! Yes others have fault in this but they didn’t pull the trigger!I think it's on the director who picked the gun up (should not have), and handed it to Baldwin, declaring it safe. Nevertheless, a sad and tragic event for all involved.
He has already confessed. And that he didn't check. As well as one of the producers? There is no doubt to the accounts. It's the liabilities. Which can be very argumentative.I'm not going to judge anyone at this point because we don't have all the facts ma'm!
I'm just glad yuse guys aren't on MY jury! I prefer to wait and see what shakes out.
I'm sure things will change five or six more times before it's over.
Posting on the thread about this tragedy, there are a lot of questions still to be answered, some of them obvious questions…some maybe not so much. Example, was the gun supposed to be empty or have blanks in it? If the latter, it would be a matter of removing the cartridges to determine if they’re blanks. Don’t think looking at the base of the cartridges in the cylinder would be sufficient. Was this an immediate live shoot of the scene or a rehearsal? My quick guess would be a rehearsal; but don’t believe this has been confirmed yet. Real weapons, used for a prop, have been modified so the injection of a real bullet can’t be done. A real bullet can’t be fully set in the chamber. Seems this might not have been the case, unless whatever ‘matter’ was propelled from the gun was enough to kill. The AD, Walls, has a poor history with safety, if what I had read is near accurate, this guy should have been in a different career by now. How is it that this guy handed the gun off to AB? Where da eff was the armorer? Haven’t heard squat yet about where she was. Cold gun supposed to be dead EMPTY or does this include blanks? Have heard more than one definition. The use of guns on TV shows and movies are in the multiple thousands going on without a tragedy. Many used are not real weapons. If the projectile was a real bullet…oly chit, how many **** ups could make this remotely possible?
ANY cartridge in the chamber means DON'T POINT IT AT ANYONE.Don’t think looking at the base of the cartridges in the cylinder would be sufficient.
