Work has been a pain so progress has been slow, but there has been some!
I washed the underside of the Road Runner to wash off 5 years of grease and grime. Yes, it was a mess in the garage, not to mention I got soaked from water running down my arms and into my armpits!! But the underside of the car looks much better now.
I had a backfire situation when I poured some start gas into my car in the winter. I was worried about having blown a "powervalve" like device in the fuel injection throttle body, so I decided to take it apart, learn and verify. The part that controls air is the IAC (Idle Air Control - in the picture below this is the part that is sticking out the bottom of the throttle body in the center of the mounting flange). I verified the operation and everything seems OK. So back together it went and back on the engine. Wasted time? Perhaps, but it gave me some peace of mind that everything was OK.
I also was messing with the dipstick to get it to sit nicely between the heads and header but without touching either. After getting it to the proper shape, I welded a bracket onto it.
That didn't work as planned, so I further modified it to use a different bolt. It looks like it is touching the header here, but there is a nice gap and it sits in between the head and header nicely.
Engine is now fully wired, so it is pretty much ready to go in except for some minor cleanup of my steering box.
I also decided to tackle taking out my master cylinder and cleaning that up. The &^$#&@! thing has leaked and screwed up my paint twice. First step was to protect my paint again from the damn brake fluid! If I had it to do over again, I probably would have used silicone so I wouldn't ruin my damn paint every time I have to mess with brakes.
Both times it seemed to leak for a bit and then stop (and I am convinced it is not from overfilling it). I believe the culprit is the heavy machining marks on the lip of the master cylinder that allows brake fluid to leak out until the gasket has had time to conform to the shape. Here you can see the heavy ridges in the lip of the master cylinder.
I decided to remove those ridges so I taped some 220 sandpaper on my workbench and then slowly worked the master cylinder back and forth. This also kept any crap from getting into the master cylinder.
Done! Now just to paint it again with cast iron paint.
