- 1:43 AM
- Jan 29, 2018
- Midland Ontario, Canada
Bob, go have a nap...
ABSOLUTELY.....but.....HOW DIFICULT IS IT TO SPELL ENGINE COMPONENTS CORRECTLY? Or perhaps the person using the word ("dizzy") doesn't know how to spell the component correctly......it's not "funny"......it just sounds stupid for a grown, reasonably educated person to talk in euphemisms......like a child......LOL
Maybe he is DIZZY
You probably never heard of this euphemism either: "picking your nose and rolling booger pills with your thumb and finger" = a soothing experience......and "dizzy never equals a distributor" ..... only to the uneducated or someone that doesn't know how to spell....I had to look that up
Six common euphemisms are:
Pretty much sums it up - LOL
- A bun in the oven: pregnant.
- No longer with us: dead.
- Let go: fired.
- Plastered: drunk.
- Time of the month: menstruation.
- DIZZY - Distributor
Time for bed - Hopefully I won’t bee DIZZY at the Town Hall tomorrow
I did not run a resistor but am considering. Upon further thought, I think what is happening is when cranking, I'm back feeding power to the electric cooling fan, electric water pump, electric fuel pump and electric vacuum pump, which is in fact easily overloading the 10a fuse.Are you still running a resistor in the system? If so it needs to be bypassed by soldering a wire across the terminals or just making a jumper to plug the wires together. I would try to isolate the system by unhooking the power to the coil and crank it to see if it blows a fuse, and if it does, unhook the power to the module and try. Why the fuse in the ignition wire?
The only time current flows in the secondary is when the actual spark occurs...its NOT a range as noted by 600ma to 2 amps and it's limited by the impedance of the coil's secondary resistance AND it's core loss or I2r loss. How do you know the peak current is...did you measure it or that's what the advertisement said? How did you measure it? Sounds like guesstimates......not actual facts.....Bob,
The only person who is uneducated about the efficiency difference between a canister coil & an E core coil............is YOU. Find some PROOF & post it that claims that a canister coil produces a hotter spark.
The heat in the spark is what ignites the A/F mixture. That heat comes from secondary coil current.
The MSD Blaster 2 & 3 canister coils have a 140mA peak current.
The MSD Blaster 8207 E core coil has 300mA.
The high power MSD E core coils have sec currents ranging from 600 mA to...2 amps.
