Frank Mopar
Gentlemen,
Checking the links does not convince me into changing. The GM HEI module's Achilles heel is heat unless the module can be adequately cooled, it will fail. Later, improvements utilized IGBT (Insulated gate bi-polar transistor) current switching circuitry, reducing the current the module must handle. The GM coil design used higher primary resistance for lower current draw and more secondary windings for higher secondary plug voltage. The spark plugs then used a significantly larger gap to give the leaner fuel charge the best chance of being ignited. This was all due to catalytic converter's inability to handle unburned fuel.
My origional question was one of curiosity not ctitism and what was the underlying reason for the change.
Bob Renton
So you answered you question of why the HEI is superior.
