adk-roadrunner
so I am in the process of rebuilding a 440 that I am going to put in my 73 roadrunner and would like all the help I cn get on which parts to purchase. so what I am going for is a nice warmed up 440 with good power that will run on 89. As of right now I have a full felpro gasket set which came with engine and an aluminum weiand intake. I was planning on using stock rods and crank and the 452 heads that came on it if they'll work they will be overhauled at the very minimum, but I am open to other work I should have done to them. I was thinking keith black pistons and a comp cams cam kit that comes with springs ,lifters,retainers,timing gears and chain, and of course the cam but not sure what grind I would need. I already haved it all stripped and will be bringing it to my machine shop guy to have the block cleaned and checked and once i know if it needs to be bored i will need to order the pistons. thanks for your input
