I've had to take my share of seized engines apart here at my business, and sometimes there isn't a lot of good stuff left. That 383 could me more difficult than others in the fact that sometimes you can't get to the rod nuts because of the block skirting. I know people will say you can soak the cylinders in penetrating oil for a time first, before disassembly but sometimes it doesn't matter. More than once I've had to torch the rods off to get the crank out, so you can drive the pistons out with something very heavy and large! I use a cut off axle for these extreme cases. Like others say if you plan on boring the cylinders and grinding the crank, throwing the rods away and exerting a lot of energy with no guaranty then muscle up ! A word of advice, check the bore first and make sure it is standard. If it isn't I wouldn't waste my time.
