HELP - RP23H61181430 ‘66 Hemi Satellite
Where is the 5-26-66 stamp located that you just posted??
I know that mine has been rebuilt as I have the dyno sheets.
If I remember, I believe that was stamped where the bell housing and trans meet? Does that make sense?
I probably, obviously, I don’t know my way around the drivetrain. It was at the farthest rear end where the pan is painted?
I’d go with MarPar’s suggestion.
My pad is mostly blank too so I’ve not bothered to remove the paint. It think the water test stamp (WT) is visible through the paint but that’s it. It was possibly milled when rebuilt. Nice paint coverage though.
Didn’t find a VIN on the rear near the oil pressure ports on mine either. But I think that was kind of hit or miss on 68s. Seems to be a lot of variations on stampings for these motors.
Good call. My engine paint is 50/50 age anyway so I thought worth the while to scrape just in case. Eh.
The number of differences between cars is surprising to the rookie I guess. At the plant level?
Is the right stamp? Come on, give me a “yes sir”. :thumbsup:
Is that down underneath just in front of the removable clutch plate? If so that would seem to be your engine assembly date (my guess?). Why it’s such different format from mine which is based on the 10,000 day calendar we can only guess. Were there 2 plants that could have assembled Hemis- or only 1? Anyone know?
The lower flange area on mine is blank
My guess is that’s blank (lower flange area) on your engine because the assembly date is on the top pad. Interesting though that your engine has what appears to be a VIN by the oil sender ports on top. That would tend to date it to sometime in mid-68 or later I guess.
I have not found a VIN on my block. I’ve looked at the oil port area closely with a camera scope and later when I removed the intake. I’m thinking that the engine build date of Dec 20, 1967 is before they began stamping the VIN on the block in 1968.
Google says 426 Hemis were built in Highland Park, Michigan and Madison Heights, Michigan in 1968. The consensus on my blocks build date was that it was built at Madison Heights. Maybe the 2 plants had different stamping procedures for awhile?
If the engine build date is 1966, does that mean it cannot be an actual HP?
My engine does not have a vin on either location.
simply the date on the raised pad below the coil. Which is where all 1966 and I think 67 engines as well
66 application will be BH ( same as mine )
67 allplication will be CH
Those pics of vins I posted are of engine Ive grabbed off the net.
Ok. So the HP2 is just badging for cars built up to around Dec ‘65? I think that’s what I was mixing up?
I ask more to check the accuracy of Mecum’s posted description. Given the clarification here it’s correct. For it would be worth anyway I would take exception if the current block was not factually correct an HP2. I understand now.
Just checking those guys. :elmer:
  • 426 CI Hemi HP2 V-8 engine
To avoid inspection I’ll run an Antique tag but PA does have “66 HP2” plate available. Would be pretty cool.
Guess I should focus on getting it road worthy first …
My original '66 Imperial had the B440 stamp on that pad location.
