Muddred12
Hey guys, having problems any advice?
Having problems with my engine, when it gets to operating temp and is there for awhile 190. The engine under WOT completely cuts out for a very short amount of time (like 1 second) like a light switch. So WOT will run fine then cut out for a second then run fine then cut out for a second. I hit 1st thru 3rd WOT and it did it probably 6 times. I thought it was the coil so i replaced it and it didn't help. I changed the fuel line filter. I have a wideband o2 sensor and I'm not running lean or rich. Any thoughts or ideas? Also keep in mind when engine has NOT been at operating temp for a significant amount of time it never does this. *update, i have upgraded my fuel pump and next i will be putting a new pick up in.
