dvw
The pump can only move so much oil at a given RPM. The relief valve shouldn't even be in mix at idle speed. Low pressure at idle is due to internal bleed. In my testing the bearing clearance doesn't affect it much. Oil feed to the top seems to be a more promenent factor. My engine runs .003" rod, .004" main, .0025" lifter bore clearance. This engine with a .095" pushrod orifice would only make 45psi@7000 vs 90psi@7000 with a .055" pushrod orifice (same relief spring and clearance's).I`ve got one of these adjustable reg. I didn't use, I have .025 main and rod clearance, and still have lower than I like oil pressure at idle w/ a hi volume pump. I tried the adjustable deal, and jacked it up to over a hundred just playing w/ it. still didn`t give me what I wanted at idle , so I pulled it out. for sale cheap.
Doug
