70chall440
- 11:55 PM
- Feb 11, 2018
- Yelm, Washington
No, they are 1 7/8" .120 wall tubing, its what I had.
Big C clamp and a socket work also.I whipped thisView attachment 958414 spring compressor up from materials I had in my stash. It fastens to the transmission with 2 pan bolts and gives me enough leverage to install those "shift kit" servo springs (getting old).
Mike
I used that method for years but occasionally it would slip off.Big C clamp and a socket work also.
How come you just couldn't chuck it up and cut one side at a time? I often thought of doing that.
One of the best homemade tools I have made in a long time is a Vee belt alignment tool, I need to get a pic. Its very basic and I got the ideal from a Corvette forum; take 2 skate board bearings and get a piece of 1/4" rod (probably about 12" or so). Grind one end to a point, then put the 2 roller skate bearings on the rod; then you place the bearings into one of the pulleys and the rod will point to the center of another pulley (or show how much you are off).
That's brilliant!One of the best homemade tools I have made in a long time is a Vee belt alignment tool, I need to get a pic. Its very basic and I got the ideal from a Corvette forum; take 2 skate board bearings and get a piece of 1/4" rod (probably about 12" or so). Grind one end to a point, then put the 2 roller skate bearings on the rod; then you place the bearings into one of the pulleys and the rod will point to the center of another pulley (or show how much you are off).
That's brilliant!
I just used a straight edge . But yours is more accurate. I'll probably make one tonight! Thanks!
Problem solving!When you need a brake and all you have is an old Beech Tool box...
View attachment 1517940View attachment 1517941
Yep, and the "neat" thing is a grew up in Smiths Falls where that tool box was made. Russ Beech used to walk across the street in his suit and help me get my control line 049 airplane going on the Hershey chocolate property when I was about 12. The local airport there is named after him.Problem solving!
Mike
