miller
Mallory dual point w/mechanical advance. Built in advance is 21. Shot for 35 degrees full in, at 2800 rpm, initial set at 14 degrees.What is your timing set at??
Thanks for that, Dave! Yes, I'll check it all across the board.From the grill side, start at the top and check slowly, horizontally across the core.
Idling in front of the shop, takes 15 minutes, or so to get to temp. That's what I'll do, at first anyway, to get temps from inlet to outlet, to see the difference. Plus all over that radiator. Need to find out what's what!
If one core had already been replaced, on the radiator, guess it's possible the other two were on the way.
