Sounds fantastic! I still love hearing about 383s alive and kicking butt!@Splangj
My orange car in post #11 is an old school, low budget '66 383 build, just .030 over with heavy TRW slugs, iron heads and a small mechanical cam. The car only has a fiberglass bumper, the rest is all steel and factory glass still intact.
Agreed! My best friend had a 70 Roadrunner, pistol grip 4 speed, 3.90-4.35 rear gears in the 8¾ he played with different ratios. Circa 1979-83Sounds fantastic! I still love hearing about 383s alive and kicking butt!
Any idea what your better 1320 ET/MPH runs were?I had fun with my 383 on the streets in the late '70's early '80's.
Direct Connection electronic ignition,
Accel super coil and 8mm wires,
2 Carter AFB 4 bbls,
Gaberial adjustable 40/60, 50/50, 60/40 shocks up front, set up for a fast rise and a slow drop,
Solid steel motor mounts,
Winters Racing built 727 with a solid rod/cable type shifter and some sort of torque converter,
Thrush straight though mufflers,
3-91 rear gears in a 8-3/4'',
Super Stock springs,
Lakewood traction bars with the rubber snubbers right up against the bottom of the car,
L60x15 tries on the rear, F60x15 up front,
11'' drums on all four corners, 3'' shoes up front and 2-1/2'' shoes on the rear,
Bearcat scanner a Cobra CB and a AM 8-Track radio,
No AC or PB's and no junk in the trunk.
Not one bit. I just ran The Circuit in town block to block light to light against anything and anybody. Sometimes the ''race'' went a distance, sometimes it was over before we got though the intersection. The ''race'' was not over till one of the two drivers let off. I never let off. My longest run was from the intersection of E. Market at N/S Sherman St. slightly uphill out to N/S Harrison St. 2,873'. If I remember correctly, it was a running start. It was a green '68 or '69 Charger in the left lane, me in the right lane, I do remember the guy was wearing a Derby hat. We were neck and neck all the way almost out to Harrison St. before we both started to back it down (red light up ahead). At Harrison St. he kept going East and I turned back in to town. Up at York US 30 Dragway (closed in 1979) you raced when it was your turn, on the streets you could get into a ''race'' at every red light. Yeah I know young and dumb or better yet, Invincible.Any idea what your better 1320 ET/MPH runs were?
