Hemi Rebel
- 1:56 PM
- Apr 22, 2012
- Where the outlaws live
I have a 400 in my 64 Belvedere with a 22 inch 3 core rad, 160 thermostat, fan shroud and electric pusher fan as well as the factory clutch fan. I'm seeing consitant temps around 210-225 dgrees in town on an evening cruise. Out on the highway it is around 200 Is this normal or a bit high? The car has yet to puke it's coolant or anything but this seems warm.
assuming the guage is correct, I would check the fan setup you have. Probably lose the electric fan and make sure the clutch fan is operating like it is supposed to. How many blades does the clutch fan have? this http://www.summitracing.com/parts/DCC-4120758/ should be all the fan you need.
I wouldnt be so much concerned about what temperature consitutes over heating or what is a good temp to run at as I would be about why your particular engine is at the temps it is at with a 160 thermostat. A good cooling system should keep temps around 5 to 10 degrees of t stat opening. the radiator sound like it should be plenty. So why can't it dissipate heat? If the heat is transfered to the coolant, and the coolant gets circulated through the radiator where is dissipates the heat to the surrounding air, somewhere in this chain of events is the problem. Either the circulation of the coolant is restricted or not moving fast enough, the air through the radiator is resticted or the cooling system capacity is not enough. The radiator sounds big enough and it should hold enough coolant. What concentration of coolant do you have?
What is the clutched fan doing? At 200 plus it should be engaging for sure. Is it close enough to the rad to get the air coming off of it?
Or better yet, is the electric fan motor sitting directly in front of the rad dead center and the clutch is on the the other side in line with the electric motor. If so, the motor is blocking airflow to the clutch. that coiled piece of metal needs to have air coming off the rad to react to.
