Does the boiling point of a coolant mixture truly dictate what the normal operating temperature should be? If I poured some other chemical into my coolant system that raised the boiling point say another 20 deg F, does that mean my engines normal operating temperature should also increase???? Other factors are to be considered in the OP's question.... For example,,,, What did the factory "designers of the car and all of its systems" deem appropriate regarding normal operating temperatures? We can answer this pretty easily by monitoring our factory instrument cluster, specifically the temp gauge.
If it's leaning clear over to the right,,, well guess what,,,, it's too damn hot.... Or, beyond or near the MAX operating temps. When something is at its MAX operating temps you have no room for normal coolant fluctuations in temp, like entering residential areas or in town traffic.....
It seems simple to me and so far many others to answer this seemingly simple question.... In summary, we don't need to think beyond the ORIGINAL FACTORY recommended operating temps in this debate, not today's engine standards.... Once again, this value is able to be monitored using factory gauges, Whatever that temp is.
