EngineerDoug
Hello all,
I have a 4160 Holley, list 3918 from '68 on my 383. I rebuilt the carb and have it running on the motor. This carb was used on 440's and has an adjustable air screw. The amount of airflow is adjusted by turning a screw just adjacent to the primary bowl vent tube. It provides some airflow below the throttle blades at idle.
My question is, does anybody have any experience adjusting a carburetor with this system? I am not sure how the various adjustments should be made - idle mixture screws, primary throttle blade position, and this airflow screw. I know you want the primary throttle blades so that the transfer slots are just uncovered, but wonder about the other two degrees of freedom.
Thanks.
Thanks.
