Thrashingcows
I just back and reread your tutorial on the other site and I am now understanding what you are saying, makes sense. So I am thinking it will be a Dodge unit and MC.
I read some place where someone side not to Tee the return line into the PS return line, rather have it go directly into the reservoir?
Only issue I have seen with putting a T on the return line is that the pedal will either drop, or raise a tad when you start the motor. Based on if it has direct flow, or back pressure from the T junction. Either way I have over 100K miles on my system with no issues other then one or two leaky hoses.
More pics of the mounting studs. 3.375X3.5 bolt pattern. And if I look at the plate it cold be rotatedView attachment 1034708 View attachment 1034709
Yes you can rotate the plate, BUT it does have a keyway that would then not align with the new orientation. If you find an alignment you like, plate and HB unit, you can mark the location and just file and make a keyway like I did.
