Sweet5ltr
Hey John,
I've been gone for sometime. The military has their iron fist on me again, but i'm very concerned on how you still are having overheating issues. You have obviously installed the 160* thermostat, have more than enough CFM being pushed and pulled through your radiator at idle from your mechanical puller and electrical pusher setup. Those are the "known's." The "unknowns" now, I would ask you to attempt to watch your battery voltage as your starter is trying to spin the engine over while at max operating temperatures (If it is dying out, I would attempt to say that you aren't running enough' cable to handle the voltage from your trunk mounted battery to your starter) and if it isn't changing dramatically, then I would return the starter immediately and replace it. That would be your first block to check. Turn down the timing to 10* initial (with a mopar elec. dist. it should be in turn 28* total after advance.) See if it makes a difference. I have been told to never run above 30-32* with today's pump gas (93 octane) and that was with 10.0:1 CR. I now am at 11.0:1, but the engine does run a bit hotter even with the E-brock aluminum heads and milder spec'ed camshaft. Check block two. I would consider going to advance and picking up a new 'stock' fan clutch, seeing if that makes ANY difference, and if it doesn't-just returning it and stating that it didn't fit your application. That would be my final check. After this, I would be looking into issues with the water pump (which have been known to occur) and order a stock replacement piece. If the water pump didn't solve any issues, then I would then move on to the radiator and ordering a summit universal unit (by measuring your current radiator) and finding one that fits the bill. PM me if you can and update me on everything that has been going on. Hey, don't feel too bad.. My three month old MSD Ignition box died the day before I left for Georgia in the RR, broke a valve spring in my Z06 and window motor went out, now just yesterday my Starter went out in the Z06 and local dealer replaced it with an off the shelf unit under warranty.-Korey
