- 3:12 PM
- May 14, 2011
- On the Ridge, TN
Haven't checked in for a while...
For those unfamiliar, I have a '68 GTX with a bastardized 440 in it (built by someone now deceased).
It is basically a '75 block with all the internals from the stock '68 440 magnum in it. Least, that's what I'm told and I can verify at least some of that is true. Forged crank, 906 heads, etc. are present and accounted for.
It has less than 500 miles on this "rebuild" and seems mechanically sound.
I have replaced a Mopar 484 cam that was in it because it wiped 2 lobes. Cam is now a Comp Cams Magnum series 270/270 .470/.470. Pretty mild, in other words, just a tick or two above stock.
Exhaust is Hedmans and a whacky 3" all the way back dual system with Flowmasters. She's a tad loud.
Ignition is the usual Mopar electronic ignition conversion. Actually, right now the car has a new A-1 electronic stock unit in it, the result of past troubleshooting with the Mopar one.
Stock control box as well.
Timing is now CONFIRMED (AMEN!) to be set at the stock 5BTDC, thanks to getting rid of the original balancer (which wound up having slipped a ton and was giving erroneous timing readings). Vacuum advance is hooked up, although this motor has demonstrated it doesn't like that too much.
Oh, car is a 4-speed if that matters. 3.55 SureGrip in a 742 punkin.
I have just installed a new Edelbrock Thunder 650cfm, the result of conferring with folks here as well as at the Edelbrock tech line. The formula says this is enough carb, right?
I put a 1/2" spacer under the carb in anticipation of avoiding heat sink.
Intake is the factory 440 one.
I set the idle mixture screws for maximum vacuum/best idle (wound up 3 turns out each). I set the secondary door spring just like the instructions said to do, then set idle at about 750RPM.
She holds a real nice solid idle and revs freely over 5000RPM sitting still.
I have made no other changes or adjustments to the carb yet.
Results of maiden voyage today:
Under light acceleration, things seem fairly normal. She definitely sounds different than when the Holley 750 was on there. I want to say it sounds "cleaner"?
She seems to lean out under moderate acceleration on up; there's a little hesitation, not so much like a bog, just like she needs to "catch up" to what I'm doing with the throttle.
Brisk acceleration (just shy of flooring it/activating the secondaries), as well as when I first pull out (she tries to nose over a tad unless I give it more beans/slip the clutch some), is telling me it's pretty lean there as well.
When I floor it, there's a familiar old "quadrajet" momentary bog, then she takes off quite well.
Long-winded way to ask for help, but is anyone else running this carburetor on a fairly mild 440?
If so, what rods/jets did you wind up with? What hole do you have the accelerator pump set at?
Looking for some sage wisdom to get her in the ballpark. She's a street car, never will see the strip.
THANKS!
THANKS!
