Keeping in mind I'm running points with a solid state VR, to your question above the three voltages on the primary side of the coil are 5.3, 4 (approximate), and 3.3 VDC. Idle is 600 rpm. At 2000 rpm the voltage is 1.8.
Ok, folks, got a TON of new information for you...
Pulled all the plugs and here's the results of that:
Yep, fuel fouled all to hell. I was surprised, to say the least. Only two looked "normal". Keep in mind, I just put these in last fall!
Ok, next thing to do was the compression test. Results:
Nothing earth-shattering there. I was relieved, actually. Not exactly a high-compression motor, but at least they're fairly consistent, eh?
Next item was checking voltage to the coil from the ballast:
Key ON, not running: 2.2V
Cranking: 9.4V
I then replaced that raggy old looking regulator with a new one:
Checked voltage @ coil again afterwards. As you might suspect, no change.
NOTE: RUNNING voltage wound up being 4.3V. Is this close to correct?
Next, the TDC checking:
Results were the indicated 0 on the new balancer was DEAD ON. At worst, maybe my eyes were off on calibration 1 degree.
Now my new balancer has all sorts of funny marks on it. Oh well.
Installed new Champion RJ12YC plugs, gapped at .035 and hoped for the best....
WE HAVE VIDEO:
Results:
The video shows it. What you see is what you get. I set the timing to 13BTDC and adjusted idle mix screws for best vacuum (about 15-16Hg). Idles @ 800.
Surprising part is what the charging gauge showed when I first fired it up:
that rascal went majorly into the + side and showed good, healthy charging the whole time the car was running.
It had never shown discharge previously, but this was a MARKED difference.
She still gets a little wonky over 4k RPM but takes it; same over 5k. Shakes, stammers and wobbles a bit up there but it will go there. I think maybe I might be down to fine tuning??
(Ok, I PRAY that, but you know what I mean)
So what the hell did all this tell me?
-Engine seems mechanically sound
-Fouled plugs with electronic ignition and less than 100 miles on them?
What the hell?
-Is voltage to the coil "normal" here, guys? Should running voltage be closer to 5V?
Starting voltage closer to 12V?
-Could the voltage regulator have been limiting voltage to the ignition, which became more pronounced as higher demand with higher RPM occurred?
No, no test drive today. I'm trying to get past pneumonia right now and literally was falling on my face working on her today - but I was determined.
What do you all think?
