I have the FSM. Was hard to pin point the section I needed to read.
At this point I think you can forget the ballast resistor.I think this electrical issue points to a problem with the key system. However, I am going to test the ballast resistor first since it is so easy to get at. Can anyone guide me through testing these two components?
Yeah ^^^^ Can't emphasize this enough.Check the starter relay and, more specifically, the ignition wire from the bulkhead connector to the relay (condition and contact). If both of those are in acceptable working condition it's the ignition switch.
Good catch. I will look for that in the FSM as well.
Why would someone bypass this?
4 Speed.Usually because the NSS is bad or the gear shift linkage is misadjusted causing the car to not CRANK with the key and they don't know what is causing it and/or don't know how to fix it. Once again, a simple circuit and easy to repair with a little troubleshooting effort.
Is this an automatic car? or 4-speed? The circuits are slightly different.
4 Speed.
That starter relay is for an automatic. There is no tab for a ground on the 4 speed relay.4 Speed.
That would make sense since this car was originally a 318 Auto, converted to a 340 4 speed.That starter relay is for an automatic. There is no tab for a ground on the 4 speed relay.
I believe that's 1970 and later.That figures, I don't have a 4-speed. If I remember correctly though, the 4-speeds have the grounding switch connected to the clutch pedal, requiring you to push the pedal to the floor before the car will start.
Aside from pushing in the clutch? Not that I know of.So, there is NO protection from starting in gear on a '69 with manual trans??
Aside from pushing in the clutch? Not thatI know of.
OK, back to the original subject. I have a ballast on order, should have it Wednesday. Amazon of all places had it.
Anyway, how do I do some testing to narrow this down? I'm thinking there has to be a way to test the ignition switch at the ballast to see if the switch is faulty.
The fact that the car will initially start and run fine, but upon restart wont run, is throwing me for a loop. If it was a bad switch I would experience the issues on the initial run as well as a restart run. From what I have read, when a ballast goes it goes all the way, something like 1/1000 where the ballast will basically weld the filament back together and run, but then break again. (this would explain why it will run fine the next day but would be incredibly unlikely)
