Please do this test . I am assuming your ballast resistor is mounted on the firewall as in the pic on page 1. Turn on your key to the RUN position, no need to start engine . Pull off the wire on the driver's side of the ballast resistor and check the wire for 12v .if there is 12v there , leave the wire off . If no 12v there put the wire back on the ballast , now take the wire off the other side and check for 12v if you have 12v leave that wire off Now take a 4-5ft piece of wire with a female spade nose connector and push it on over the ballast resistor pin . Now , put and alligator clip on the other end or safely secure it to the pos. side of battery. Start the car and take it for a run. make sure the wire is secure and don't burn on the manifolds or get caught in the fan or belts . you know what I mean . By doing this you eliminate all the wireing ignition switch, amp gauge, , fuse panel . bulkhead connector etc etc . All that is running now is the ignition wires from the ballast to the coil and coil to the dist . if the engine is still stalling out , the problem (or one of them ) is at the engine ....coil, dist etc . If the engine don't stall now , the problem is from the ballast resistor back to the ignition somewhere. I have been told there is a situation where your engine may not start because some units were built where boths sides ign1 and ign2 go through the single coil ballast resistor but I haven't seen one . give it a try if it works ok , well you know where to look , if it don't back to square one .
