gkent
Looks like a decent piece for the money.
Summit brand is what we have been using recently as well.Summit Racing™ Billet Steel Timing Sets SUM-G6606R-B
Part Number: SUM-G6606R-B
$99.99
Timing Chain and Gear Set, True Roller, Double Roller, Billet Steel Sprockets, Mopar, Big Block, Set
See More Specifications |
Timing Chain Included:
Yes
Timing Chain Style:
Double roller
Camshaft Gear Attachment:
3-bolt
Maximum Advance/Retard at Camshaft:
4 degree
Maximum Advance/Retard at Crankshaft:
8 degree
Cam Gear Included:
Yes
Cam Gear Material:
Steel
Crank Gear Included:
Yes
Crank Gear Material:
Steel
VVT Gear Included:
No
Tensioner Included:
No
Thrust Bearing Included:
Yes
Bolts/Studs Included:
No
Gaskets Included:
No
Offset Bushings Included:
No
Quantity:
Sold as a set.
Notes:
Includes torrington bearing.
Special Attention:
3-bolt cam gear.
Cam movement will put stress on the gear drive mesh - wear & tear , timing fluctuationsI appreciate the patience with me on this stuff.
I'm guessing that fore/aft movement of the cam has to be limited to keep the lifter wheels in proper contact.
I've never checked to see how close the timing chain is to the back side of the timing cover. The cover always slipped in place and I never thought about it.
NoCan you buy that separately and install…….
Yesis the cam gear machined especially for the Bearing?
Had no idea about the cover flex
F-I-N-A-L-L-Y !!Sounds like you’re on the right path.
A cam the checks all the right boxes for anyone is such a personal thing and hard to put into words.
I’ve been following your posts on the subject. Your choice sounds like it could be the right one. The next size up in that cam lobe profile series might work for you too.
For sure a one-on-one conversation with Dwayne will get you what you’re looking for.
Good luck.
What is a guardian angle?guardian angle
It's a carpenter thingWhat is a guardian angle?
