I can’t wait to read the before and after results of a roller cam.
I’m not sure how you drive this particular vehicle, but we tend to be rough on things in my world. Have you considered putting solid lifters on the hydraulic roller cam and tight lashing it? If it’ll see some spirited high rpm action, it may be food for thought. I’m sure you’ve discussed it all with Porter.
I'll double down and ask what's the advantage over a solid roller cam?For clarity, you mean solid roller lifts, correct?
This is over simplifying, but roller cam failures happen when a lifters roller bearing gives up. When the rollers bounce it is hard on the needle bearing or bushing. If you run a solid roller lifter on a hr cam which has no lash ramp about the only lash the lifter will see is when the engine grows. So there is less lash. If we set a engine with aluminum heads to 0 cold..it is about .007 hot. Iron headed engine even less. Less lash is less lifter bounce. Hopefully prolonged lifter life more comparable to a hydraulic roller lifter.I'll double down and ask what's the advantage over a solid roller cam?
