My shift points are pretty close to that taking onto account I have a 3:55 end. My 3rd gear hits at around 65MPH under full throttle. Anything less it’s in 3rd before 25MPH. 1-2 is there around 12MPH under closed throttle. Everything I’ve read about the older 727’s ‘on-demand’ shifting or passing gear only happens when it’s floored assuming the rod is adjusted properly as you’ve described. There isn’t any part throttle kick down or a delay in shift without WOT. This came with the later 727’s I think post-’66 or later. Older trans can be modified to obtain a part throttle kick down with a kit and/or some governor mod’s but haven’t come across anyone that’s done this. Adjusting the rod gets very slight changes...at least as I’ve played with this.
