sputnik 440
Capt Jim
How about the level of fuel in the float bowls? I run my DP850 4150 with the level just slightly above the center mark. If it is too high, you will run rich. In my experience, this had an effect on the vacuum. It is always the first thing I look at and set. You might check to be sure your floats are fitting properly and not deformed or leaking.
