Average Joe
Thanks! The plan for right now is the usual hotchkis upgrades and better wheels/tires until I get a big enough space to tear it all apart and build something new. I’m thinking along the lines of C5 corvette based suspension but still pretty undecided
There are a couple of companies that offer brackets that allow you to weld/Bolt in the the C5/C6 Cradle in the front and rear. I have been researching this for a little while for my 68 Charger.I am considering a Viper Chassis now but track width is about 4 inches wider. Progressive Automotive sells the the weld in frame stubs for front and rear. Dobbertin Permormance sells bolt in with the option of narrowing the rear cradle. He also sells a adapter for the transaxle to run a transmission behind the engine instead of the torque tube that the corvette uses. Although he offers the ability to narrow the rear at the moment the front is standard width. The track width is wider that the charger so it creates a problem. Also GZ Motorsports sells a air pump for the LS engine can be mounted pretty easy. That is if you continue to have problems with crankcase pressure. I would assume that you are only running about 12 Pounds of boost. 600 hp is a safe max on stock internal ls engines before they fly apart. Next time 2j swap the charger LOL. People will really get pissed.
Thanks,Joe
