4406bbl
Where the vacuum advance starts is kind of built in around 8", to get the 10 degrees you need will be tough to get working reliably at idle if you can't keep 10-11" of vacuum at idle in gear. A custom made at least $1000 torque converter is one way, you put it in gear and it does not pull the engine down, making tuning easy. I would get the initial to 18- 20 maybe 24 degrees is the number, you know the engine wants that and more at idle and see how good you can get it to idle in gear, then decide if you want to chase the vacuum advance or limit the mechanical. I would not drive the car with that much initial and unknown mechanical. In your case 30 degrees inital with the mechanical limited and little ported vacuum advance for a clean cruise might be as good as it gets until you get a looser converter at idle, manual trans is so much easier.
