JedIEG
I am trying to do an at home allignment while the world is on fire and I can't go to a shop to get it done professionally. Ride height is set how I want it. I have the UCA adjuster all the way in on the rear and in the middle on the front yielding
Driver side
-1.2 camber, 1.2 caster (calculate using 20°turn in/out camber measurements)
Passenger side
-1.3 camber, 2.1 caster
Turning the driver front side adjuster all the way out I get
Driver side
-0.2 camber, 2.4 caster
My target is -0.75 camber and 2.5 or more caster.
Should I try to maximize caster over camber or vice versa?
Should I maximize one side over the other or sacrifice one being close to the target to get them equal?
FYIs.
I am using an angle finder app on my tablet set against the rim of the center cap on my rallye wheels to measure angles so I know it's not to most accurate way in the world but is what I got.
Also Considering moog offset bushings or the nuclear option of fully adjustable UCA in the future if I can't get close to the target.
Driver side
Passenger side
Driver side
FYIs.
