I'm looking forward to the post-installation road handling report.
Thank you. I knew that I'd make sense of it, though I didn't know how that I would.I never had any doubt. Well done.
I just had mine realigned a few weeks ago. Mines setting pretty low in the front. I think I got +5 and 5.5 and it drives great. Im going to crank it up another 1/2” and get it realigned next spring. I’ll try to remember to tell them to print it off.Nice job and very detailed and it sounds like you're happy with the way it drives! That's a win.
I'm a bit concerned about your extreme caster numbers though. I almost don't believe them - not that you didn't measure accurately, but remember the story I told you about the backup shop that did my car when my normal alignment shop was busy? They got me +6.5 degrees caster both sides and were high fiving me. Within 50 miles later, something felt wrong and when I took it to my normal shop, they discovered that the more than normal positive caster was achieved by doing something with the tie rods that I can't quite recall. I believe it was extending them too much and one of them was at the very end of the threads and binding or something. My point is - in all of my reading and working on these classic B-bodies since 2010, I've never heard of any of us or any of the magazine article write-ups achieving +8 degrees positive caster. Something feels off. Just humor me, put the car on the lift since it's now been driven and double-check all connecting pieces and make sure there's no binding or threads backing out. I had +5 degrees caster with my Hotckis V1 UCA's and +4.5 degrees with my Firm Feel UCA's now on my car. I can't imagine QA1 UCA's offer twice as much adjustment as those two. If they did, they should be outselling all of them. Not trying to bust your balls, just make sure the numbers aren't fooling you somehow.
I always enjoy reading your threads. They are well thought out. You seem to have a curious and inquisitive mind and sometimes question the status quo. Refreshing.Increased caster will certainly result in greater steering effort.
A guy at FABO had over 8 degrees of caster in a Duster with a 16 to 1 manual chuck. I don't know if he is a strong man but I'd guess that it was not easy to steer when at slow speeds.
The procedure to check caster is simple. To check the left side, you turn the wheel to the left by 20 degrees and place the gauge on the hub...
Then, you turn the brass knob until the bubble in the center gets to zero.
The steering wheel is then turned to where it points 20 degrees to the right. This can be done with the gauge still attached or removed.
Once the wheel is at 20 degrees to the right, the gauge is set to level using the small bubble at the point:
With that leveling bubble in the center, you can now read the center scale for caster. The base for the gauge is magnetic and does rotate. I have spun it numerous times to ensure that the numbers I'm reading are repeatable. They have been for the most part. The gauge is claimed to be accurate to within 1/4 degree. I had to remove the center caps in my wheels to have a flat spot to rest the gauge. I had to hold the gauge against the wheel since the magnet won't stick to aluminum. If I've been doing it wrong, I'd welcome any advice on how to do it right.
