ksurfer2
Block and tackles make it easy to move heavy loads through mechanical advantage. This can also be applied in reverse. Could there be an advantage gained by rigging a 1:2 ratio throttle cable? Normally, when a gas pedal is moved 1" it moves the throttle linkage 1". With a simple doubler rigged to the gas pedal, moving the pedal 1" would now move the throttle linkage 2". Is there advantage to be gained by opening the throttle twice as fast (or moving the gas pedal half as far to achieve full throttle)? This wouldn't really be practical for any street driving, but on the track where you are at idle, or full throttle (for the most part), it seems as there could be advantage gained.
These are the thoughts that pollute my mind when I am bored at work!
