452's & 906's are both open chambered heads. You need a set of 915's or 516's.
Ok. This is why I posted, to get feedback from guys that have the experience with these engines to know what makes them run best. Even though I am on a very limited budget, I want to do this right as much as possible the first time and not have to tear it apart again a few years later.
I appreciate the craigslist links and the effort you’re putting into this. I guess what I mean by trying to find them locally is a 20-30 minute drive, not an hour or more. I had seen the $175 heads before and considered them, but by the time I added up getting new hardened seats put in, and new guides, it was in the ballpark of $800. There is someone nearby that has 346 heads for $50, but they say they’re just cores. I could go look at them and see what they’re really like. If the seats and guides are within spec, I may just get them. They should have induction hardened seats, right?
But, it sounds like the thing I should focus on is getting the right pistons. So, that’s what I’m going to do. It really baffles me why no one makes a replacement piston for this engine that has zero deck height. I can find lightweight, fancy, high tech stroker pistons all day long, at pretty reasonable prices. Try to get an old school, cast piston at the correct compression height and weight matched to the originals, not going to happen. I was talking to a guy at Ross pistons about what I wanted, which is basically what you guys are saying I need to get, my only twist was to get them matched in weight to the originals. I basically need a 440 .060 oversize piston (that has a C.H. of 1.913) turned to .052 oversize instead. That puts me at 0.05 below deck which I thought would be decent enough. The weight of the cast piston could be adjusted easily to match the originals. His reply was they could do that, for about $900... Gee, thanks dude, I’ll get right back to you about that...
I too have looked into aftermarket heads to raise my C/R on my 400. From what I have read is the 75cc aluminum heads will raise compression about 1 point, but they will perform like the stock cast 452 heads power wise. Something about the aluminum not producing the heat to burn the fuel like the cast heads. I hope what I read is wrong, as I would like to go the 75cc head myself. Since $$$ is limited, I would look at the biggest bang per buck. I also remember you stating your heads are shot. I see your dilemma.
Hughes Engines talks about this in an article regarding cast iron vs aluminum heads. In short, at least the way I understand it, even though I’m raising my compression almost 1 point by using the 75cc heads, the aluminum dissipates the heat from combustion faster than cast iron, which reduces cylinder pressure to effectively lower the compression ratio by about 1 point. But, since I’m using a cam that builds significantly more cylinder pressure than the original cam, I should still be seeing a performance increase over what I started with. The bonus is that this head still flows better and is lighter than the 452’s, so I still come out somewhat ahead by getting the Eddy heads I think. For about the same money as what I’m going to pay just to get my stock heads usable, I can get the Eddy heads that flow better and are lighter, and they claim burn better, but I doubt I see any real benefit there. But if I ever have to submit to emission tests, that might help some then.
You got lucky. Every big block Mopar Trick Flow head I have had through the shop had the valve guides too tight, and needed to be honed.I don't recall what my cylinder head guy charged to check my trick flow heads, but it was not all that much. I also had then check the flow just to see if they flowed as advertised, so I would have to break out the costs from the bill.
Those heads checked out fine and did not need any work.
