What CC are the Iron heads you'd be using? Do you have the compression calculator and all the numbers(rod length, deck height etc...) set? I don't have the rod length, piston height, deck height chart on me at the moment.
As your finding out custom pistons get expensive really fast. The KB-240 is about all there is off the shelf ($470), and it still is not zero deck (about 0.024")
The Brodix B1 B/S heads have about the smallest chambers for a big block. Normally 65cc, and can be milled even smaller. Problem is they are expensive. and use an offset intake rocker arm.
Really, if cost is a concern and the cylinders are good, just put the small cam in it, use a thin head gasket, and spend the $1,089.64-50.00 rebate that expires on the 28th ($1,039.64.pair of heads) on the 75cc Edelbrock E-street heads.
https://www.summitracing.com/parts/edl-5090/overview/
You will still need to spend the extra money on head bolts.
I think these will work with your small cam and stock rocker gear. Not sure on pushrod length, it would have to be checked.
That is only about 8.5:1 compression, but with the small cam and better heads run way better than it did before with the worn out heads.
If on a budget, I think starting to change pistons, or milling block/heads will just open a can of worms of having to spend extra in other areas like the balancing, or extra milling to fit the intake to the milled heads/block, and that is even if the block decks are square.
If your going to re-machine everything and but new pistons you may as well just start off with a stroker kit.
This.
If you're on a budget, leave the short block alone and put on a good set of cylinder heads with small chambers. Higher compression and better flow. It'll be the better bang for the $. You'll spent 2 times as much freshening up the shortblock and won't run as well with crap heads.
Yea me too......if you are buying pistons then get something that will put you around 9.5:1 like I said.....it'll work with what you have and then later you can upgrade the heads to some nice aluminum heads and still keep the compression in the useful range. Edelbrock makes a nice aluminum head that is 88cc I believe in an open chamber just like the stockers and a couple in closed chambers (84cc & 75cc). That a cam and intake down the road and you'll have yourself a hell of a motor to play with.Sorry, just read about the stiff pistons. That does changes thing. sorry, pat
Hang on, my computer just locked up on me. I think it’s getting tired from calculating all these part combos tonight... ;)Ok do this.......What does 9.0 compression ratio get you with your combo now if you bump the heads down to 84cc later on?
Using 88cc heads with a 0.020” steel shim and 4.380” bore and stock flat top pistons, compression is at 7.4-1. Changing to 75cc heads bumps it up to 8.1-1, assuming I can use the same steel shim gasket. But I get conflicting information about that too.
I read through this whole thread, wanted to reply to a lot of comments but didn’t. I’ll just say a couple things
1. IMO You can’t teally build a “budget motor” and expect it to last forever you said you don’t want to rebuild it in a few years... get your priorities straight and figure out what path you’re going to go down.
2. IQ52 is a talented builder, he does this for a living, and I would consider following any advice/guidelines he posts. If you think he’s criticizing (he probaly is) but it’s becaise he’s been answering questions like these for a long time.
3. If it was my motor and I didn’t want to be rebuilding it in a few years first thing I would be doing is taking it to the machine shop to be serviced/checked (bored/cam bearings etc... the works) it seems like what you’re after is longevity on a minimum wage budget, sorry but probaly wont happen.
Guy chimes in claiming he re gasketed a motor that sat for 30 years woth rusty cylinder walls and it ran for another 100k Miles in 3....2...1...
You know before I built my motor (keep in mind I’ve never built an engine) I planned on taking my old 440 putting some trickflow heads on it a comp roller cam and a new carb and It was going to be the baddest motor around... I quickly realized there’s a lot more to it then slapping a few new parts on, ended dumping around 12 grand into my stroker, but you know what now I know it’s built right (mainly because I didn’t build it lol)I once had a 440 out of a motorhome that I regasketed and surfaced the heads and made 400hp on the dyno! Said no one ever!!!!! Sorry 67Coronet you made me hahahahahha!
