400Magnum
With a steel shim (0.020) head gasket and 88cc for 452 heads, I get a compression ratio of about 9.4-1. Not a bad start, which is about the top of the range of compression that Crane recommends for this cam. This should be livable with premium pump gas, shouldn’t it?
If I get the 75cc Eddy heads later, using a multi layer gasket that’s 0.027” thick, compression goes to 10.5-1, which should still be very streetable, right?
Whatcha think?
Whatcha think?
