Modern Bullitt build
US Car Tool supplied custom trunk hinge supports with themini tub kit but I’m not sure how they fit and they don’t look right for thisbuild so I modified the original mounts. I made a cardboard template and transferredthe shape to the original mount. This finishes the original look I was workingon.
Pat
With the inter wheel wells out the aft end of the rockers isopen. So before they go in for good I vacuumed, cleaned , and sprayed Eastwoodinternal frame coating inside. Over 46 years old on the east coast they lookgreat inside and now they should be good for another 46 years. I wonder if I’llbe good for another 46 years??
Pat
Before and after
Nice work, as always.
Are you TIG welding? Sorry if it's a dumb question - I'm still learning about welding and have a long way to go. The welds look very small so it didn't look to me like MIG...
I was going to ask the same thing. He's either using a TIG weld, or...
No I used a Mig.
Thanks!
Pat
...he's just that good with a MIG welder.
Damn, Pat....incredible build.
Amazing work! Threads like this make some of us want to start another one just to try to step up our game. Impressive work
Epoxy the inside of the trunk and rear frame rails with DuPont2505S DTM epoxy primer/sealer today.
Now its ready to weld the trunk floor and inter wheel wellsin.
Pat
Welded in the trunk floor today and hope to put the interwheel wells in tomorrow. The floor fitgreat with little persuasion. I was ableput a bead of seam sealer at the tail panel and where the interior floor meetsthe trunk floor. I also used my spot weld wherever I could reach and plugwelded what was left.
Pat
Wow . . . impressive work is an understatement . . . my mini tub wheel wells look like patchwork quilts ! ! ! Very NICE ! ! !
good lord, with the work so far i cant wait to see the finished product, wow, impressive sir!!!!!!!
Epoxy primer the inter wheel wells along with few otherparts today. I hope to install them permanently tomorrow.
Pat
I have been away from the Charger for a few days as my youngestgraduated culinary school (CIA) in NY. He is only home for 3 weeks then back toschool for a business degree.
I welded in the wheel wells and have the bumper & trunk supportspainted and ready to install.
Pat
All the metalwork in the back of the car is complete and nowit is time for the front of the car, motor, 6 speed, and RMS suspension. (Thefun stuff)
Pat
I just remembered today marks one year into this build thatI’m shooting to finish by next spring. It is so true how fast time fly’s by aswe get older :-(
Pat
Wow, that's some awesome work. I saw the wheels again at the beginning of the thread, man those are so sweet. Nice job.
I drop the K member and remove the bump stops from theframe rails. The K member has SSBC disc brakes and is in good shape with atight steering box and I would like to sell it if anyone is interested? I willpost it for sale soon.
Pat
I cut the bump stops off so that they could be reusedon another car if someone needs a set?
Cleaned up the frame rails and fit the RMS K member.
Pat
Even with all my calculations, double checking with the differentvenders, and other threads with similar suspensions it was a relief seeing thefront wheel on the car with great clearance and no rubbing issues with in thefender.
Pat
Very nice work! My welds never look that clean with out some dressing them up some. When you use the spot welder do you still have to have the holes? Getting ready to start some work on my 68 that will be close to what you are doing. Floor, trunk, quarters and tail light panel for sure. Anyway great work and will be following your progress.
No holes for the spot welder as it needs the metal to metal contact.
Thank you and good luck with your 68!
Pat
