SublimeSixpack
Man, that build is coming along nicely! Very impressive!
And those rims turned out great!
Looking good Keepat! Very clever, I assume your just going to weld a spacer in to fill the void? Does your T56 have a reverse lockout like the Viper trannies? I installed a Viper T56 in my Charger and love it, the tightest area for me was where the bell bolts to the tranny on the driver side top corner where the Vipers hydraulic bleeder is but don't know how different it is to yours. Nice looking work for sure!
Yes when I know how much space the trans will need in the tunnel I'll weld it up. As for the reverse lock out I'm sure it has one but I have yet to think about how I will activate it. How did you activate it? Thanks for the heads up on the tightest bolt to get to, I'll need to check there.
Thanks again!
Pat
I just used one of those crimp on spades that has another terminal allowing 2 wires to be put on one terminal connecting it to the brake pedal switch. Works out well, unless you have your foot on the brakes it won't go into reverse. I also wired the original neutral safety relay into a brake switch mounted to the clutch pedal so it won't start unless your holding the clutch and there's been at least 2 times now that I have turned the switch with it in gear and that switch saved me. Not so much a bolt, just that top left corner right where the tranny meats the bell was close to the floor. I have a thread on my install if anything in it helps but like I said mine was a Viper T56, I think it's titled Viper T56 install in the motor and drivetrain section. Your work looks great!
