ODZKing
I posted this over at the other forums as well. I would like to get opinions.
When I change the oil in the 67 and 73, I generally use good oil, put some zinc additive in. Then I usually keep a quart of oil, among other things in the trunk, especially for trips. So I happened to be at Walmart yesterday and thought I'd pick up a quart of oil to toss in the trunk. I found this. Not terribly expensive which made me wonder, and I know it is a no name brand. But like everything else, someone has to make it for them ... but the interesting thing is it says for 88 and older, with extra zinc. Anyone ever seen this stuff or used it?
Just because it is a no-name oil doesn't mean it is bad. I mean who was Brad Penn before Hemmings and such started talking about their oil with the added zinc.
However all I can seem to find is it is distributed by Warren Performance Products.
http://www.wd-wpp.com/upload/saved/Accel_1_PCMO_SpecSheet.pdf
The various reviews are much the same as on the other forums. Folks who have tried it say its fine, others say I won't try it because it is cheap. Just because it isn't more than $10/qt doesn't necessarily make it junk. But I would like to see more info on it.
