Trying to keep the progress moving on this rear axle install . . . and having fun too . . .
So, this is what I've got for the process and the order . . . taking it one part at a time. . . .
First, these seals need to go into the adjuster/non-adjuster plates . . .
The non-adjuster ( left ) goes on the driver side - the adjuster ( right ) goes on the passenger side . . .
To help with this the lathe helped me to make this from 2" PVC pipe
( it was so slightly too large on the outside, and too small on the inside )
So I cut away enough to allow the seal to fit properly . . .
Fits perfectly . . . now to install them . . .
Done - installed - the tool worked great ( just wish I had metal to make the same tool ) . . .
And this is the order ( and direction of the parts ) as they get installed . . .
- the bearing/race goes in the direction shown ?
- - - - - ASKING - race first on the shaft, then the bearing to capture it ?
- then the collar to capture the bearing
- then the foam gasket
- then the backing plate
- then the other seal ( this is more like paper than steel )
- to the flange of the axle housing . . .
And this seal gets mounted into the end of the axle ( in this orientation ) ? ? ?
Adjuster/non-adjuster plate - foam seal - backing plate
Other seal goes against the flange on the axle housing . . .
If I didn't mess up something in this photo documentary - I think I've got it now . . . and I've already gotten started on the process - (2) seals already installed . . .
