Got a chance to get into the shop and get a couple things done so far this weekend . . . ( yeah, it felt GOOD ! ! !)
First . . . think I've finally figured out my E-brake cable routing . . .
The clip is not on the aluminum fitting, so it's not sitting true in the bracket
( cut the original bracket and welded it into my holder )
From there, you see it goes under the 5.7 Hemi cover over my original tunnel hump . . .
Then, further back, and under the rear seat, the cable comes back out into the passenger area . . .
And then it goes through the floor ( actually the back edge of the floor ) . . .
Here's a little better view of the cable routing . . . it's under the seat and should not be in the way . . .
And then under the car I'll finish up the attachment to the (2) rear brake cable that will be held by the bracket on the left . . .
Next . . . is the rear axle brake lines . . .
Made the "new" brake lines for the rear axle, they needed to be adjusted to fit the new 3" narrower rear end . . .
Here' the Driver side connection . . .
And then it runs over to the axle mounted T-fitting . . .
Then out the other side of the T-fitting, it runs around the differential housing . . .
Through the brake line clip and over to the passenger side connection . . .
Which has been routed and bent similar to the original lines . . . ( just 3" shorter . . . )
Feel good to get a couple things done on the car . . . finally . . .
