Meep-Meep
дворянин
First time ever and I'm sure it didn't mean to! I took my green 66 out to run a few errands and while waiting at a stop light the idle hiccuped a couple of times and died! Yes, this is the car that was running high 12's just a few weeks ago. When I heard the RPM drop briefly (like a miss) I tapped the throttle and the RPM's went up then another hiccup and it quit like I turned off the key. I cranked it while giving it a few pumps and nada. I then popped the hood and saw I had fuel in the carb (wasn't out of gas) and tried to restart and again nothing. Then I pulled the dist cap to have a peek but didn't see anything obvious so I put it back together and checked for spark at coil wire and it was good. Tried to start it again and still nothing. At this point some guy offered to help me push it across the street. Finally out of traffic I popped the dist cap again and saw the carbon tip in the center worn but at the time it didn't look alarming so back together it went. I was going to check for spark at the plug but decided to try and start it again and it fired up and ran like normal! WTF! I drove it back to my shop and when I got there it died again. It restarted right away and did the hiccup thing but it was too dark to dig into it.
Here's what I have: Orange box and the stock black coil that was on the car when I got it. I'm 99.9999% sure it's electrical and sort of want to blame the orange box but need to do some basic tests before I condemn it. My question is: Has anyone had similar issues with their car? Could this be a temperature related issue - as in the orange box get's hot after ~10 mins of driving - not necessarily from engine heat but from the electrons racing around - and crapping out because of a bad component? Screwing around for a few minutes trying to start it might have given the box an opportunity to cool off. Or similar issue with the coil? I will dig into it tomorrow one step at a time and hopefully find the smoking gun. :edgy: Thanks for the input.
