Jonathan
Ok i did thatWell the pump might be bad . It should fill the trans up more then that though
Pop your trans lines off the rad maybe you have an air pocket?
Force feed the fluid in after lines are off ! Give it a little air blast with your compressor
I have 10 quarts in it now. Its reading over full. I jacked the front of the car up and ran it in neutral then the back.
It still won't move under its own power. But it spins the wheels when its jack up better then befor
