Hemi Rebel
- 6:40 AM
- Apr 22, 2012
- Where the outlaws live
For now I would stick to no t stat. That way you can fill it and not worry about having an air pocket. Water boils at 212 f. With the cap on and under pressure that should put the boiling point high enough that it is not an issue. When its running, run your hand around the front of the rad. Do this to make sure the temp is even throughout. Any kind of restriction and the temp difference will be noticeable.how far is the fan from the rad? Does it have a shroud? How big is " isn't that big "?
