I will go look for the 62 distributor today and let you guys know what I find from it (PN, etc..)
On my 67 dual point, I changed the vacuum advance that came on it to an NOS one that I bought. I will find out what is stamped on the arm of the one that I didn't use once I find that guy again.
So from reading through everything, the point to point measurement should be 1.025, and not the 1.25? If so, then I believe the cam stop in my 67 dual point should be ok? If so, that removes the need to dissect the 62 dual point that I have for parts.
The distributor that I put back into the gtx was an aluminum bodied distributor (which I believe makes it a Chrysler). Its cam measurements appear to be within spec, so not sure why such a very small gap is giving the proper dwell (which was confirmed with two separate meters).
This was something I thought of last night in regards to my vacuum advance issue. If that plate has slop in it, that could be why the car acts up once the vacuum comes into play.
The car ran ok with the vacuum disconnected when I was running the 67 dual point, but not great.
I understand what you guys are saying with re-indexing the distributor. Thank you for the clarification. I just had to wrap my head around it.
One thing I did notice when I put my single pt aluminum bodied distributor back in.
I tested it the same way I tested the 67 dual pt.
I set initial timing to 0*, and rev'd the motor (with vacuum disconnected).
The mechanical advance was less than the 67 dual pt. Now this distributor appears to be working properly, so I don't think the specs for the mechanical advance for the distributor listed in the FSM have to be double to get the reading on the balancer.
Either way, mechanical advance appears to be less than the dual pt. But, the car seems to run better with this one (with the vacuum hooked up, which does have less advance 7.5 vs what is installed (which I think is 10)). That just means with this carb providing carb vacuum, my motor wants the vacuum because it wants more advance (more than the dual pt could give just on its own without vacuum help)).
