miller
The why is, two different distributors, most likely two different advance degrees/curve.Now, with the exact same initial setting, with the dual point distributor, the car doesn't start as quickly. Not sure why.
Is it? You figure the base # for initial, knowing your 'on the plate' advance.So the distributor is making 14* mechanical.
Something you might try...use a clear plastic degree wheel, held over the rotor, to see how many degrees it moves, when it goes to full advance. Example...mine moves 11 degrees, X2 means on the plate it has 22 degrees.
Need that on the plate #. On your Prestolite, it's fixed by the plate that's installed. To change that number of degrees, plate has to be changed.
Total advance of 36, minus the 'on the plate' advance degrees, equals the initial degree timing.
Your point gap/dwell is another issue. (I kinda remember .017" - .018")
