Zeppelin264
Umm. Your running a hydro cam and you have valve lash? Thats not good.
Hmmm... time for rockers. Ouch. What about the lifters not bleeding down? Completely incompressable
You can order custom push rods. Have to figure out your measurements. Or do both. I did the old school Crane Iron Ductile rockers and they are awesome, if you can find a set they should be fairly cheap.
Do they compress when you spin the motor by hand? If the motor is running then they have to be compressing.
No, stock type lifters do not bleed down.
Can you depress by hand any of the rocker/pushrods (collapsing a lifter) while it's just sitting there quietly?
Had kinda the same issue with my 440. All was good during break in and for the first few hundred miles then clackty ckack on start up. Sounded like it was coming from # 8 cylinder. Once warmed it was all but gone but still a slight noise. I pulled the suspect lifters and took them apart, nothing obvious. Now this valve train has the Comp XE268h-10 cam and lifter package with Isky ductile rocker and custom Smith bros push rods. I talked to my engine buidler and he advised to tighten up the preload by 1/4 turn and see what happens. I did and no help. The trick was switching to Lucas hot rod oil and a Hi pressure spring in the stock pump. Still has a wee bit of noise cold but made the trip to Reno and back with no issues,and that was cruising at 75 with bursts to 90. I called Comp and asked about their lifters having problems, never heard of it they said. Well I beg to differ as there are lots of posts on the quality of their lifters. Anyhow give the oil a shot, sounds like you already have the HV-HP pump covered. Oh yeah these were the Hi-energy lifters.
Beat me to it Bee.Well it's been a long time, but I hate adj pushrods, I'd rather go with adj rockers, IMHO. I don't think oil viscosity makes all that much diff unless you've got crazy bearing clearances.
Ok, IF there are no collapsed lifters (you checked them all, right?) and IF the cam isn't damaged, then get a pushrod length checker tool (they're cheap and readily available from places like Summit and Jegs) and measure for the proper length pushrods.
If you'll get the proper length pushrods in the engine, you won't need adjustable anythings.
Oh man, you're going to get a lot of opinions on that one.That sounds like a plan... and likely cheaper lol! How much preload should there be on the lifter anyway?
I'd confer with the cam manufacturer on their recommendation, but the consensus when I was going through all this seemed to be anywhere from .020 to .050.
